I am about to retile an old shower and the old floor drain will be too low for the new tiles once the old mosaics are removed. The substrate is concrete. Is there a product which will push into the old drain pipework once the grate is removed to increase the height and not have to cut out the old shower outlet?
Hi @pwmonger1
There are drain extentions made for you purpose with different height of extentions , an example of one of them is as follows
https://www.bunnings.com.au/art-plastics-50-x-45mm-dwv-pvc-extension_p4760010
Have fun just check your drains diameter for good fits.
A warm welcome to the Bunnings Workshop community, @pwmonger1. We're thrilled to have you join our community and look forward to seeing and assisting you with your home improvement and garden projects.
Great to see you've received advice from @Jewelleryrescue on extending the height of your shower drain. Our resident Bunnings D.I.Y. expert @EricL will also be online later today and happy to assist.
Can I please request you to provide some photos of your shower area and the drain? This will help our members get a better idea of what you're dealing with and enable them to provide more tailored advice suited for your needs.
Let me know if you need a hand uploading images on the site.
Thanks,
Akanksha
Hello @pwmonger1
Just to add to the suggestions made, I recommend having a look at the PVC Slab Adaptor. These PVC couplers are meant to slide into existing pipework concreted into place. It can be cut down and adjusted which will allow you to slide in a new floor waste.
Thanks Eric, that's exactly what I'm looking for
These look like exactly what I’m after but still a little concern as I maybe wrong but I’m look at either using a shower pan over tiles or I may need to remove tiles not sure yet but on shower pans don’t they have a screw on fitting at the drain? Or is that only the top piece.? I know I have to remove the step in part as shower pan is around the same size as where the step and screen is attached. I will add some pictures but I’m hoping once the step is removed the pan will fit without removing any other tiles, as wall to edge is 900x900. PS at some stage I will have to do floor as well just not sure on my approach to that yet if I tile over the top or try and find in Australia floating PVC floor tiles they have in the states. The first picture is the floor drain.
Hello @downunder
From an installation point of view, it would be better to remove the tiles and start fresh. In this manner you won't have any lingering doubts about any of the tiles failing and coming off. In regards to your shower pan, it will come with installation instructions including how to install the proper drain for it, odds are it will still require a puddle flange to operate correctly.
Just a friendly reminder that any plumbing work will need to be completed by a registered plumber for safety and compliance.
