How to fix broken drain tile supports?
mjooash
Hi there - looking for suggestions to remedy (even if temporary as is a rental) this situation?  Tile moves when walking on it and is a bit of a hazard.  The little support knobs are snapping off for some reason.  I might just ask landlord to fix but if there’s a cheap non-permanent option I’d rather just do that so we can live with it. Thanks.
Re: Broken Drain Tile Supports
Hello @mjooash
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your shower drain.
In the interim, I suggest putting Surface Gard 8mm Clear Round Rubber Bumper - 25 Pieces on all the interior corners of the tile drain. This will keep it in place and prevent it from moving around as you step on it. I recommend wiping the surface of the tile surround with DIGGERS 125ml Isopropyl Alcohol - 125ml to remove any grease or oil on the surface.
mjooash
That’s fantastic, Eric, thanks - will give it a try!
