I'm after some thoughts/ opinions about newly renovated bathroom in a 1970s unit
Am I correct in thinking a piece of water-stop is missing where tiles meet cavity sliding door?
The floor falls from shower door towards bedroom door (will be carpeted), & water escaping from shower pools near bedroom door. No drain in bathroom floor. Builder said it falls this way so cavity slider door fits over tiles. A water bar installed under shower door. Water sometimes leaks through vertical openings beside door.
Decorative trim on shower hob creates barrier preventing drainage, even though fall on hob is correct. Water drains from small section where tile sits proud of the trim.
TIA for advice on whether these are faults, & on possible solutions.
Hi @Sunflower1,
Unfortunately, the answer to your questions will be contained in Australian Standard 3740 (Domestic Wet Areas), which I do not have access to.
I'd suggest you contact an independent building inspector to inspect the work and provide a report based on their findings.
Unfortunately, I am not qualified to comment on the validity of the install in terms of the Australian Standards, but I would expect to see a fall away from a non-wet area and a continuous water stop across the full extent of the doorway.
Thank you Jacob. I was looking into inspections, but quotes were over $900. Will reconsider.
Hi @Sunflower1,
I can say that it doesn't quite look right, but unfortunately, I don't have access to those standards that explain what about it isn't right, if it turns out that it is.
They can be expensive, but they will be invaluable in that they will provide you with evidence based on the Australian Standards that you can use to have these issues rectified.
Apologies that I couldn't be more help.
Let me tag a few other members to see if they can share their thoughts @Sunflower1.
@Nailbag, @chriscam82, @TedBear
Hi @Sunflower1
These issue appear to be a combination of design and construction faults.
1. No water shouldn't be exiting the shower in the first place. The shower tiles should all fall towards the shower drain. As a safe-guard or need to, a metal trim channel can be siliconed in place to prevent water exiting under the door. If the door gets a lot of water splashes, you could also use a PVC shower door deflector trim. Images of both below.
2. The shower floor should fall to the drain and the bathroom floor should be dead flat if not falling to a central drain used for over-flow/flooded scenarios. The legal requirement for a drain various between states. You can ring your local building authority to check how this applies to you. In any case, there is appears to be a preparation fault in the floor levelling prior to tiling.
Ideally, both cosmetically and practicality wise the tiles should have finished in the bathroom side of the cavity slider. Image below. The comment by the builder that the floor needs to fall this way to fit under the cavity slider is I'm sorry to say ridiculous and completely incorrect. The gap under the door can be adjusted by either adjusting its hanging height up from the carriages the door rolls along (5min job). And/or in the case of not enough adjustment, the door can be trimmed shorter (45min job).
3. The builder needs to rectify all of these issues. However, in doing so correctly and not by quick fixes, the floor tiles need to be lifted and redone. But this will impact the bathrooms waterproofing and possibly triggering the bathroom to essentially be redone.
Do you know if he's a registered builder and part of any building association? I would be contacting them first to get all the facts straight and any support they can offer on your behalf. And have you made final payment as this is something I would be holding back on for now.
Hi Nailbag,
Thank you for all that info.
Builder is member of HIA and VBA. Unfortunately I made the final payment before learning of the issues.
He installed a water bar across doorway after I said water was exiting shower, which now prevents this as long as not directed toward vertical gaps beside door.
Shower floor and the hob surface fall towards drain. However, metal trim on inner edge of hob creates surface tension that holds water on the hob. While not major structural issue, if I don’t squeegee after showering, my understanding is that water sitting (pooling?) on hob could lead to problems later.
Weirdly, he did mention that he may have to shorten the doors, so not sure why he didn’t take that route.
I’ve also learned that door frames inside bathroom should be hardwood. Fairly certain they’re MDF all through.
Looks like I need to get a report done and decide whether to make it official.
Thank you again
