Hi, water slowly dripping despite tightening the holder, guess must be the washer. how do I change the washer from the attached tap? This is the 1990s tap. In the 2nd photo, underneath the sink. No leakage under the sink though.
Hello @gavin16
Thanks for sharing your question about how to remove a tap in order to fix a leak.
Your tap handle is held in by an anti-vandal tap screw. If you were to run your fingers or look underneath the handle you will see two slots. These slots are made to accept a special tool that will allow the internal screw to be taken off and the tap handle to lift up. I've placed a picture below of the Kinetic Spout And Handle Repair Kit. I want you to look at the flat tool on the very left with two prongs pointing up. This is the tool you need to remove the locking screw.
Once you have the tool, gently line up the prongs pointing up into the bottom slots of the tap handle. Once the prongs are locked in place hold the tap handle steady and gently turn the tool clockwise. Once the screw comes down and out lift the tap handle slowly as parts of the locking mechanism may fall into the drain.
Hi Eric,
I hv unscrewed the tap handle and it looks similar to this. Do I still need the kinetic kit to remove and replace washer?
Hi Gavin.
You've moved onto a different sink and taps?
Get a shifter onto it and rotate right...
Water turned off?
Washer ready?
Good luck! ![]()
Hello @gavin16
It's great that you've received fantastic advice from @Noyade. The picture that's been posted is the perfect way to remove the spindle off the base of the tap assembly. Because you've removed everything, you will not need the special tool anymore.
Please keep us updated with your progress, we look forward to seeing your tapware fixed and ready for use.
