How to replace sink tap assembly?
zillah
Having an Impact
Dear Experts
Our kitchen sink's tap assembly is leaking as shown in the attached video in the link below
Looking to replace it with a premium quality (i.e not cheap) preferably with its spout
Any recommendation which one should I get ?
https://imgur.com/a/iKM7T2G
ThxIMG-20251031-WA0022.jpgIMG-20251031-WA0023.jpgIMG-20251031-WA0024.jpg Hint: I was able to upload images here but not video ,,,,therefore I uploaded to imgur.com
Re: How to replace sink top assembly?
Hi @zillah,
Thank you for your question about replacing your wall tap assembly.
There are a few great options which include both the spout and the taps, such as -
You can also piece together a wall spout with a wall top assembly to achieve the same outcome.
You might like to consider using our Tapware & Shower Head Installation Service as part of the replacement process.
Let me know what you think.
zillah
Having an Impact
Thank you very much Jacob
zillah
Having an Impact
Hi Jacob
1-I have got this old spout has two parts I guess can I find a replacement ? please see attached photos
2-To undo the nut that hold the plastic handle for the spindle I couldn't find a tube spanner as plastic hole is tight ,,,,,what tool do I need to use ?IMG-20251101-WA0020.jpgIMG-20251101-WA0022.jpgIMG-20251101-WA0023.jpgIMG-20251101-WA0021.jpgIMG-20251101-WA0024.jpgIMG-20251101-WA0025.jpgIMG-20251101-WA0026.jpg
Hi @zillah,
You should still be able to find a replacement. The spout being in two parts is just so there can be a mechanism to rotate the spout. The pipe through the wall should still be the same.
The grub screw at the connection between the two parts would need to be removed so you can take the top off. You would then rotate the lower part anticlockwise to remove it from the pipe in the wall.
Did you get the tap handles off? It looks like you've already replaced them?
It looks like you should just be able to pull them off.
Noyade
Morning @zillah
"To undo the nut that hold the plastic handle for the spindle I couldn't find a tube spanner as plastic hole is tight ,,,,,what tool do I need to use ?"
With a screwdriver, gently pry out the the 'blue ring' - it's just held by friction - which opens the area for a socket (from memory around 14mm?)
zillah
Having an Impact
Thx Jacob for your help
Yes I did get the tap handles off by using a grinder to make the hole bigger as I didn't know the way that Noyade explained
zillah
Having an Impact
Thx Noyade for the tip
