Hi, I'm very new to this community. Recently a mechanism that does the toilet flushing lever has broken. Picture attached is the same toilet in another bathroom but highlighted part that is broken. I was told that this toilet is too old and replacement parts are impossible to find now, and a brand new toilet is required.
Any suggestions please will be much appreciated before we make a new purchase
Hello @tzeherng
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your cistern flush.
Just a friendly reminder that any plumbing works must be carried out by a registered plumber for safety and compliance.
A possible replacement for the flush in your cistern are the Fluidmaster Dual Flush Toilet Cistern Valve And Button and the Kinetic 17 - 25mm Single Flush Outlet Valve. Both are designed to be retrofitted into older cistern sets. However, due to the complexity of the replacement procedure, it is best to have a professional plumber assess if the parts suggested will fit.
If the flushing mechanism can't be replaced, I can only recommend taking into consideration changing your toilet completely.
I also recommend checking out the stores Toilet Installation Service, especially if you are looking for a professional to install your toile suite.
Hi Eric,
Thank you for your help. This is very useful.
Just so I am clear - Are you suggesting I might need both replacements or either one or the other?
Thank you.
Hello @tzeherng
It's one or the other but not both, I propose showing your plumber both options (on the website) and they can decide which one would be best suited to your cistern.
