Laundry makeover with Kaboodle cabinetry
Christie78
Cultivating a Following
This started when the need to move on from Blue and yellow was a must!
This laundry lacked functionality- it had no bench space, no cupboards. Just a small 2 door cupboard under sink.
We decided to go for an industrial style laundry with some much needed  bench space and more storage.
We kept plumbing to same position, to keep costs down but added overhead and under bench cupboards. All Kaboodle products and hardware.
We included pull out draw for dirty baskets to slide out next to washing machine.
this top loader is multi function and is washer/dryer combo. Added some Bunnings penny tiles for splash back!
Materials
Kaboodle cupboards and base units/overheads. Darker doors (top cupboards) special order!
https://www.bunnings.com.au/kaboodle-450mm-alpine-macaroon-cabinet-door_p0315240
villa board -
https://www.bunnings.com.au/james-hardie-2400-x-1200-x-6mm-2-88m-villaboard-lining-2400-x-1200-x-6_p...
Penny tiles for splash back -
https://www.bunnings.com.au/decor8-310-x-315-x-5mm-white-gloss-penny-ceramic-mosaic-tiles_p6661853
waterproofing,undertile  https://www.bunnings.com.au/crommelin-1l-one-coat-rapid-under-tile-waterproofing-membrane_p0356887
Grout https://www.bunnings.com.au/davco-1-5kg-white-sanitized-superfine-grout_p6820063
Tiles - https://www.bunnings.com.au/johnson-tiles-300-x-600mm-marble-white-rectified-ceramic-wall-tile-carto...
LED strip for under overheads.
https://www.bunnings.com.au/lytworx-5m-rgb-and-white-led-strip-light_p0341464
Tools
We used a tile cutter we already had.
Bunnings tools used were;
RYOBI 1500W 184mm Circular Saw,
Hole saw for tap mixer and plumbing - https://www.bunnings.com.au/craftright-16-piece-holesaw-set_p6372275
We also used Bunnings tile accessories, for wall and floor, and hardware tools for cabinetry.
Steps
Step 1
Removed old laundry cabinetry and started demo of old tiles. We took off villa board on walls and replaced with new.
 then we water proofed room, and measured out Kaboodle cabinetry.
Step 2
Then waterproofed entire room, before installing new tiles
Step 3
We then had plumbing hooked up and finished cupboard install. Then grouted tiles, including splash back.
Step 4
Here is before and after
Step 5
Final result
Re: Laundry Love Make Over
Hello @Christie78
What a beautiful laundry transformation. The dark brown colours of the wall cabinets neatly contrast the soft benchtop colour, and the LED provides excellent lighting. My favourite part is the stencil that you placed above the tiles.
Thank you for sharing such a wonderful project.
Re: Laundry makeover with Kaboodle cabinetry
Love the design @Christie78 very practical and the LED light strip is always a fav of mine. But the backsplash verse makes the project unique well done.
Christie78
The laundry room!
We had a decent size room to work with, that had zero functionality. One small sink and cupboard was all that was in the room. Very dated yellow and blue tiles, It was screaming to be updated. We transformed the space into a lovely functional space with the storage.
Materials
1. we designed the space with Kaboodle Cabinetry.
https://www.bunnings.com.au/products/kitchen/kitchen-cabinets-pantries
2. We choose timber top bench, and sealed
https://www.google.com/aclk?sa=L&ai=DChsSEwjRnIvUgpOPAxWaNoMDHafMKDgYACICCAEQFBoCc2Y&co=1&gclid=Cj0K...
3. Feature splash back tile
Penny round Tile
4. Timber moulding for detail trim
decrotive timber trim
Tools
1. After demo, we waterproofed walls and floor, using products and equipment from Bunnings. Including villa board sheets.
 2.  Tiling glue, grout and tooling all purchased at Bunnings.
3. Pluming - hoses /fittings and tape wear all Bunnings.
Steps
Step 1
 1. Remove all contents, including jackhammering all existing tiles. Removed plasterboard.
2, waterproof walls and floor, we replaced exisiting plasterboard and replaced with wet area Villa board.
3. Tiled floor and walls.
4. Ordered and installed new Kaboodle cabinetry. These were special order.
5. Grouted tiles and added penny tile splash back feature, with led Strip light.
Re: The laundry room!
What a transformation @Christie78!  Your laundry now looks so fresh, modern, and functional — such a rewarding upgrade. Amazing work turning the space into something so practical and inviting.
Many thanks for sharing.
