Does Bunnings cut wood to size?
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include Melamine and Plywood.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
jennib35
Custom cut shelves
I would like to buy 8 white melamine or timber shelves for existing bookcases. Each shelf measurements is 760mm x 260mm. Are you able to fill this order?
Re: Custom cut shelves
Welcome to the Bunnings Workshop community @jennib35. It's wonderful to have you join us, and many thanks for your question about our cutting service.
Discussing your needs with the saw operator at your local Bunnings store would be best. Your 260mm measurement could be under our safe operating guide limit, depending on the sheets you're having the shelves cut from. Given this, I'd suggest popping into a store and having a chat with a friendly team member to see how we can assist with your project.
singhs
Cut 200x50mm pine sleepers to size
I would like to know if your store at Keperra,The Gap QLD will cut these sleepers to size.  Approx 8.  Will purchase them at the store.
Re: Cut 200x50mm pine sleepers to size
Hello @singhs
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and many thanks for your question about our cutting service.
Would it possible for you to tell us the sizes that you are after? I recommend speaking with the saw operator at your local Bunnings store. This would be the best way to find out if your cutting measurements are within the safe operating guide limit. If they are, the store should be able to cut the sleepers to the sizes that you need.
Once you list the sizes that you require, I'll give the store a call and make further inquiries.
singhs
Appreciate your prompt reply.
I need the 3m lengths cut to 2.930mm (8 sleepers).  I am making a base frame to place a 3mx3m shed on.
Singh
Hello @singhs
I've just spoken to the trade desk at Bunnings Keperra and they have confirmed that they can cut the sleepers at that size. However, please be aware that the shop saw blade is very rough and and not made for precision cutting. There could be a possible variance to the cut you are after.
Please make sure to wear personal protection such as gloves and goggles when handling the sleepers.
Fatsquare
Cultivating a Following
Re: cutting easycraft panels
Thanks. I also need some panels for my bedside wall. 900mm is not fit for it because the bedhead is already higher than 900mm. So 1200mm is perfect. But I check thr brochure of easy craft. 1200 is not available. So I am thinking of the 2400. Just wondering if I sepcial order 2400m from Bunnings,  will store cut the panel as request for 1200mm?
Hi @Fatsquare,
When placing your order, it's best to discuss your needs with a team member at your local store. The sheets are MDF and that is something we cut, but due to them being a Special Order item, it's best to confirm with a team member or manager at the store that they are able to cut the panels and have them ready for you when you are picking them up.
Be advised that this is not a precision-cutting service. At a minimum, the 2400mm sheets will be cut into two 1198mm sheets as there is 3mm wastage from the saw blade. Also, there can be a variance of a few millimetres on cuts.
slugg
Cutting 25mm panel
Have asked at one store if they can cut rubberwood panel (25mm thickness) was told no
Do other stores have this capability
SE suburbs Melbourne
Re: Cutting 25mm panel
Welcome to the Bunnings Workshop community @slugg. It's wonderful to have you join us, and many thanks for your question about our cutting service.
Was it this Practa 2200 x 600 x 25mm Rubberwood Timber Benchtop? If so, we are unable to cut benchtops on our saws and only panels.
I'd suggest the best way to cut these benchtops would be at home with a circular saw. I recommend having a quick look at this guide - How to choose the right power saw for the job by @Adam_W. Here is a link to our best advice: How do you make long and straight mitre cuts?
Please remember to wear personal protection such as gloves, goggles and a mask when using a circular saw.
