Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Hi, I have a pretty niche requirement here. I need to cover a specific area of the fence to satisfy pool safety checks.
As circled in the photo below, the area measures about 70cm x 7cm. The current palings I applied are standard 12mm in thickness. Can Bunnings help cut this specific size? If not, what are the alternatives? At this point, style doesn't really matter to me.
Thank you
Hi @rocketman,
Unfortunately, you are not going to find a piece of timber that perfectly fits that gap.
The best solution is to simply grab another paling and rip it down to fit the gap. It would be easiest with a circular saw, but it is entirely achievable with a handsaw.
Just measure the gap accurately, ensuring there is a small expansion gap between the palings, mark those dimensions on the paling and cut along the line.
If you take your time, it isn't particularly difficult.
