Hello to insulate my shed I was thinking of using either Foil board insulation polystyrene insulation or underfloor insulation, but I'm not sure what to use. If I were to use either the foil board or polystyrene insulation I was thinking about using liquid nails or some sort of glue to glue it to the panels but there might be a better option out there. I live in Ballarat Victoria and it gets very hot in the shed. So if I could get some help that would be great.
Hi @S3RG404,
Foilboard have a range of Installation Guides which detail the installation method in different situations. I'd suggest you have a look at the Small Shed Installation Guide.
Their recommendation is to attach Foilboard Spacer Blocks to the wall of your shed using high-temperature neutral-cure silicone such as Sika Black NO2 Davco N Silicone Neutral Cure, then attach your Foilboard Insulation Panels to the spacer blocks with the same silicone. After this, any seams or joins should be taped with Foilboard 48mm x 50m Silver Tape to finish things off.
A note for our New Zealand readers - The use of foil-faced insulation products has been banned in New Zealand.
