How to countersink screws?
Ricochet
What’s the best way to countersink screws?  I generally go too far or too shallow or the countersunk hole is crooked and part of the screw sticks out.
JDE
Becoming a Leader
Re: countersink screws
Ricochet you could try using something like a P&N Countersick drill bit first (available at Bunnings)  they are adjustable and then set the torque on you driver at a lower level. JDE
Hi @Ricochet,
It's great to see you have already received a helpful reply from @JDE.
Are you using a countersinking bit or a standard drill bit for the holes?
The P&N Quickbits certainly appear to be a great way to get a perfect countersunk hole. Although it doesn't come with a drill bit and is a two-step system I've been using a P&N 13mm Rosehead Countersink Bit which I have found to be very effective. It still requires you to to keep the bit perpendicular to the surface and you'll want to be careful that you don't go too deep.
I'd be interested to hear what our other members use to get that perfect countersunk hole. Let me mention @woodenwookie, @r23on, @Brad, @Bundaboy and @Stuardo who are all keen woodworkers to see if they can share some tips and tricks.
Please let us know if you need further information or had questions.
Just a normal drill bit.
Hi @Ricochet,
If you are just using a normal drill bit any of the above-mentioned products will make your life a lot easier.
Please let us know how you go using a specific counter-sinking bit or if you have any questions.
r23on
Hi Ricochet
If you are having trouble with depth I would stick with the P&N Quickbits as pointed out by Michell and as a rule the drill is the correct drill bit to suite the screw save a lot of time and mucking around.
Regards
redracer01
Re: How to countersink screws?
Hello @Ricochet
This is what I use when I do counter sink holes. My favorite in my bit box.
Cheers,
Red
Screenshot_2020-08-25 P N 10G Quickbit TCT Cut Smart Countersink Drill Bit.png
Brad
I have a set of countersinks with pilot drills and a vix bit for hinges.
I prefer screws with either square or hex head so they won't slip like philips heads may and bits with some length so you can get the screws straighter for driving.
