How to hang a shelf on plaster wall in garage?
calccom21
Building a Reputation
Hi All,
   I wanted to hang a shelf on a plasterboard wall on the garage (photo as per below). And might put something weighing 7-8kg. The dimension of the shelf is around 550 x 135mm. Can the plasterwall able to support the weight. The shelf has hook on the back (4 corner)
1. if I drill on the stud, how long mm or screw should I need?
2. If I can’t find a stud point, is there any plug I can use to lock it to support the weight?843B03F9-637F-4758-9832-5D02C8E7D15E.png
Re: Hanging a shelf on plaster wall on garage
Hi @calccom21
Thanks for sharing your question about hanging a shelf on plasterboard. I suggest using an 8g x 60mm Chipboard Screw. I recommend a minimum of four screws to anchor the shelf in place.
If you happen to miss the stud, I suggest using a Tox M6 Flip Toggle Bolt which is rated with a holding capacity of 20kg. But just to be safe it's best to have at least one part of the shelf anchored in a stud.
I also suggest having a look at this discussion - How to mount wall laundry cabinets to metal studs? by @Rob89. Although the discussion is about a steel stud, the technique used to anchor the cabinet to the wall is applicable to your project.
Please make sure to wear personal protection such as gloves and goggles when working on your project.
Re: How to hang a shelf on plaster wall in garage?
Hi @calccom21,
I trust Eric's advice contains everything you need. Let us know how you go with the project.
For other readers, the guide How to hang just about anything is always a great resource.
