Hello,
I was looking for a material (wood, plastic, or composite wood) that would be both light and strong enough to make a mediation stool (see photo below). They are usually made of pine, but I was looking for something lighter... I was wondering if someone could recommend some materials that are available at Bunnings.
Thank you!
Kind Regards,
Acala
Hi @Acala,
Unfortunately, I am not aware of a material that would be lighter than pine, while still being strong enough to support the weight of a person.
Composite timbers are, in my experience, heavier than pine, and the only timber I am aware of that is lighter and readily available is balsa wood, which would definitely break under the weight of a person.
I'd suggest you stick with the conventional approach and use something like 184 x 19mm DAR Pine or 235 x 19mm DAR Pine to construct your meditation stool. You could pair this with some butt hinges to emulate the design you have shown above.
OK great, thank you. That is good to know that pine would be the lightest and strongest option. 😊
