Hi
I'm trying to work out from the timber cutting list text exactly what to ask for when I go into the store.
It's not very clear to me from the way it's been written so hoping someone can clarify.
This is the project on the Bunnings site: https://www.bunnings.co.nz/diy-advice/home-improvement/furniture-upcycling/how-to-make-a-folding-wor...
Should this be interpreted as:
From a sheet of 2250mm x 600mm x 30mm ply, I want 1 x section that's 945mm x 450mm 30mm ?
From some dowel that comes in 35mm x 2.4m lengths, I want 2 x lengths of 1650mm ?
From some structural pine that comes in 90mm x 45mm x 2.4m lengths, I want 2 lengths of 945mm each ?
Thanks for your question, @Nywgad. Our resident Bunnings D.I.Y. expert @MitchellMc is currently away but will be happy to clarify that cut list for you as soon as he can.
Also tagging our experienced members @DIY4Knuckleheds, @Dave-1 and @Jewelleryrescue for their thoughts. Thanks for your patience in the meantime.
Let me also welcome you to the Bunnings Workshop community. We're delighted to have you join us. Don't hesitate to reach out should you need a hand getting the most out of the site.
Akanksha
Good Evening @Nywgad
A warm howdy
and Id like to say welcome to the Bunnings Community page
Love the project you have decided to give a go and I really like the way they have done the base of the feet for the table!
The ply mentioned in the notes is from the New Zealand Bunnings store. Also I cant find it on their site in NZ 😕 I can find 18mm or 20mm ply (you could substitue and just allow for the difference in height)
The 30mm dowl looks like its available.
Maybe you could adjust some of the measurements to suit what is available in store (lots of time end of stock runs out and a new product is replaced) I just bought some yellow gum decking timber at end of run and know it will no longer be available.
From what I understand they have given you a list of pieces you need and also the whole pieces that you will need to buy. You have to buy the whole piece and then ask the Bunnings people to cut it for you. It will make it easier to transport it home.
You could cut out a scaled version from cardboard of the full pieces and then trim them down at the sizes they want for the shelf. I have drawn pics so many times trying to nut out an explanation and it really brings it home.
Hi @Nywgad,
Using IBS Mini Panels 1200 x 600 x 18mm CD Untreated Plywood would provide quite a solid working surface for most hobby projects. If you wanted to achieve an even more solid surface you could double up on one of these sheets and glue them together.
I'll provide feedback to our team so they can take another look at this article.
