I’m seeking advice as to what type of tap timer I could use that will turn pump on for 1 hour a day to water lawn via pop up sprinklers. The power switch I assume would need to be on along with the tap which is located alongside the pump as per photo.
Hi @Garrygaz,
Did not spot it at first look, that's an extension cord weather cover with motor power lead plugged into extension cable - interesting.
We can't use a regular tap timer so instead I am suggesting a programable Smart Plug that can be controlled locally or via a phone app.
TP-Link Tapo P100 Mini Wi-Fi Smart Plug.
Basically the extension lead plug is removed and the Smart Plug is plugged into that power point and... the extension lead plugged into the Smart Plug. We need a photo of where the extension lead is plugged in and hopefully it is under cover like a patio area because the Smart Plug cannot be exposed to the weather.
P100 Features:
Hello @Garrygaz
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about adding a timer to your pump.
It's great that you've received excellent advice from @AlanM52. I was thinking along the same lines and was going to suggest an analog device such as the HPM 24 Hour Heavy Duty Weatherproof Outdoor Timer. But the more versatile and programmable TP-Link Tapo P100 Mini Wi-Fi Smart Plug is much more convenient. My only added suggestion is to place the unit inside an Arlec 5 Outlet Weatherproof Electrical Enclosure Box to protect it from the elements.
Hi Alan
this is the power cord location, probably not really water proof, although EricL mentioned the Arlec cover not sure if that would be suitable any further advice would be appreciated.
many thanks for your excellent advice
Hello @Garrygaz
My best advice is to make sure that the device you connect is protected from the weather. Another possible option is to get an electrician and have a weatherproof plug set installed under a covered area where you can attach a Smart Wi-Fi timer.
Many thanks mate, I will certainly get back to you if needed👍
Thanks Eric for you assistance 👍
Hi Alan
ive purchased the Tapo plug unfortunately not having a lot of success connecting my phone to it. I’ve plugged it into a power point and the light flashes green and orange. I then go to the app and push add device select the right model P110 and then select Bluetooth to set up it keeps coming back that my phone can’t find device.
any thoughts?
cheers
garry
Good morning @Garrygaz,
General overview:
Bluetooth is used to speed up the initial connection to the Tapo app, but it is not used for controlling the device (P110) after it is configured.
Tapo smart plugs will not work only on Bluetooth and need a home wi-fi network (2.4 Ghz) to function.
It's likely you are unable connect to the app via Bluetooth because of visibility and/or permission issues.
Check the Bluetooth system setting and try again.
Let us know how you go...
