How to cut a floating shelf down to size?
Jersey1975
Building a Reputation
How can I cut a floating shelf down to size and the cut end look presentable when it’s not up against a wall? Thank you
AlanM52
Re: cutting a floating shelf down to size
Hi @Jersey1975
Most likely iron-on edge banding.
Screenshot 2026-01-15 191444.jpg.
White Iron-on Melamine Edge
Jersey1975
Thank you
Hello @Jersey1975
It's great that you've received excellent advice from @AlanM52. Just to add to the suggestions made, I recommend inspecting the angle bracket type being used and making sure that it will not be visible should you cut the shelf.
