How to add Lugna corner unit doors?
aussieorchid
We are wanting to build some office storage and I was looking at the lugna range but I can’t find anywhere if you can add doors to the corner unit specifically the 2048mm 580 deep unit.
Re: Lugna corner unit doors
Welcome to the Bunnings Workshop community @aussieorchid. It's wonderful to have you join us, and many thanks for your question about the Lugna range.
If you're looking at the Lugna 2048 x 900 x 580mm White Corner Cabinets, they are an open design with no doors. All of these corner cabinets do not feature doors.
Ok thanks that answers that question. What would my options be for office storage with a corner cabinet. Wall space is 110cm on one wall and 136cm on the other 2.4m ceiling so space is a bit limited. Would Kaboodle corner units stacked on each other be an option as I am keen to go floor to ceiling.
Hi @aussieorchid,
We do have the Kaboodle Corner Kitchen Pantry, which can have a door. You would need to add side panels to it to cover the exposed screws. It's 2200mm high, so not quite to the ceiling. However, three stacked lower cabinets won't get that close. A bulkhead can be installed at the top to give the flush look.
You could potentially stack the lower corner cabinets.
Thanks I will check that out.
