How to finish edges of a VJ panelled wall?
Sugar
Making a Splash
Hi DIY Lover,
There are plenty of posts regarding the VJ panelling, but I would like to start a fresh as per my problem :).
My plan is to have this wall dedicated for hanging pictures, frames etc.
This is something I am aiming for.
I have plan for different walls, but to start with this one and my questions are indicated with the mark.
In below image, green shadow is the wall, I would like to do VJ paneling.
How do we finish around the edges indicated by the red line ?
How do we finish the VJ panelling before the skirting board shown in the image below ?
What could be the easiest way to work around the areas such as this power plug ?
Thank you.
Re: How to finish edges of a VJ panelled wall?
Hi @Sugar,
It would look like this.
When installed, you aren't going to see the corner of the VJ panel at all; you would just see the two 30mm legs on each side of the corner.
hi @JacobZ  This is my write up about this solutin I found. https://www.workshop.bunnings.com.au/t5/Living-and-Bedroom/Easycraft-VJ-panelling-bedroom-feature-wa...
This timber https://www.bunnings.com.au/22-x-7mm-2-4m-shelf-lipping-tasmanian-oak_p0084040?srsltid=AfmBOoqKiY9Bd... turned out boe Godsend for me to fix my issue. This is very thin timber but really helped me with the project.
@JacobZ  the picture helped me to understand. I was thinking like how trim is placed on tile around the edges and where only the lip of the trim is visible. Thank you.
