Hello workshoppers! I've recently moved house and have two large linen cupboards in the hallway that i'd love to revamp - photos below. They look to be a plywood with wood veneer. What's the best way, and the best products ,to paint them white? Thanks!
Hello @aly
Thanks for sharing your question about painting your veneer linen cupboards. Looking at the pictures you posted it appears to be plastic laminated doors. One quick way to find out if it is wood or plastic is to sand a small portion of the door. I suggest sanding the inside corner of the door where it won't be seen.
You'll notice that the sanding dust will either be wood or plastic and if it is wood, you'll see it on the sanded surface. But if it is plastic, it will be just white.
If it is a laminated door, I suggest having a look at the Dulux Renovation Range. It is specifically designed to go onto laminated surfaces. However, if it is a timber veneer, it will still have the properties of wood and standard painting practices will apply. Generally, the surface will need to be sanded and a primer and topcoat applied.
Here are some amazing painted laminated kitchen projects our Workshop members have shared:
Thanks @EricL just gave it a quick sand and it's come up white so I guess it's plastic. Will take a look at the renovator range and see how I go. The doors are an odd size, and quite large so still looking like painting is the cheaper option for the moment.
Afternoon @aly
I have some office styled bookcases that are laminated, Definently plastic lol I sanded them so they no longer that smooth feeling to touch and then used laminate paint over them. Then painted an undercoat and final coat. They came up really nicely and didnt cost a huge amount.
white knight 1l white satin renew tile and laminate paint
If you would liketo see the how to of retrofitting the laminate bookcases heres the link Bookcase retrofit to create a garage library
One thing to note is that the paint will become more "fixed" the longer it is on the doors, so less likely to be scratchable type deal.
Looks great @Dave-1 . Thanks for the info and for sharing your project ![]()
