Heavy rain comes in the top of our timber windows. Have tried numerous rubber sealants. Any ideas or suggestions?
Many thanks Bunnings
Regards
David
you have hit on an idea I had and that is to run a strip as you describe on the top outside of each window so the strip closes against the frame. I could even pad along the inside of the strip with a runner to give extra protection against rain running down the wall??
Very much appreciate your advice.
Regards
David4321
Hi Dave
Your idea of a bottom door seal positioned at the top of the window is a great one. I had been thinking along a similar line (inverting the seal?). Perhaps even add a runner at the top of the seal to help against the rain water that runs down wall.
Really appreciate your advice and I plan to give it a go. ( you may find a separate response floating about as I learn the communication process).
Best regards
David4321
Thank you Jacob . Very grateful for your experienced advice. Will add the products to my Bunnings shopping list which even identifies the bay and aisles where I can find each product.
Regards
David4321
Morning @David4321
First stop is verifing that the awnings work, I really like them and how they are supposed to work but with the water you descibe I am thinking it runs under the awning piece and then into the window area.
If they are dry then maybe the other ideas
But it would solve your problem if they are letting water through.
Good point, thank you - I will check the awning-wall seals.
Regards
David4321
Hi @David4321
I was in the dentist's waiting room this morning flicking through one of those "Better Homes than Yours" magazines and found an ad where a young woman is clearly admiring her angled hinged windows. I thought of this thread - and wondered how this window manufacturer can seal a window like this?
Yet we're having no luck with yours?
Interesting Noyade.
Heading out to Bunnings to pick up some of the seals and other items recommended.
Also - I am wondering if this door seal on the top outside of the window where it shuts against the Frame might work?
Thanks to all the helpful contributors.
David4321
Hi David @David4321
Would it be worth talking to the manufacturer/installer for advice/suggestions?
Or are these windows quite old?
Hi @David4321
That seal you've just put in might actually stop or at least lessen the amount of water travelling into the interior side of the window. I'm just worried that the mounting tape might not be enough to hold it in place. I propose adding extra mounting tape such as Scotch-Mount Extreme Double-Sided Mounting Tape 2.5cm x 1.5m.
These are cedar windows made 15 years ago @Noyade. Will check if manufacturer is still around.
Thank you
