How to build an indoor bench coffee table?
alxc
I want to build an indoor bench coffee table with these materials.
Is there a treatment I must apply to the pine wood first? And what type of screws should be used to attach the wood to the bench leg.
Re: Indoor Bench
Hello @alxc
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about building an indoor bench.
I would suggest sanding the surface of the  Specrite 70 x 35mm 0.9m Short Pine Run Of Mill all around to remove any timber splinters that may be present on its surface. I suggest giving it a fine finish with a 240grit sandpaper. Once the surface is prepared make sure to clean all the sanding dust off before you paint it with your preferred sealer or paint product. I suggest looking at Cabot's 500ml Satin Water Based Cabothane Clear Polyurethane or Dulux 4L Aquanamel Semi Gloss White Enamel Paint - 4L.
Here is a handy step-by-step guide: How To Paint a Wardrobe (the techniques used are applicable to your project)
alxc
Re: Indoor Bench
Thanks for advice, I will try this out.
