My little side table
Super_D
Becoming a Leader
I just made this little side table, from 3mm Plywood Pine Premium and 42X19 DAR Pine and a Merbau panel.
It was a nice little project and it is all just glued together.
I use my table saw for the strips I just glued a block on the end so I could sand them
all together as one piece so that they would be all the same.
391581101_10230218904238485_164897292711299662_n.jpg391600630_10230218903398464_4873829448262097158_n.jpg
I also use the table saw to cut the top and the bottom Merbau panel together so they would match up.
391578731_10230218903958478_4779614980341555566_n.jpg386109077_10230218903598469_1947160419596251139_n.jpg391578665_10230218903758473_7286066206455892206_n.jpg
391598970_10230218904158483_3137788750444976793_n.jpg391574983_10230218903518467_1819808910697804340_n.jpg
I just used a clamp to bend the ply wood and use a router to finish the top and bottom and add 4 little feet underneath
Materials
PVA Glue
Decor and Furniture Lacquer from Kmart (because I had it)
https://www.bunnings.com.au/specrite-1200-x-300mm-18mm-timber-panel-merbau-fj-laminated-1200-x-300-x...
https://www.bunnings.com.au/42-x-19mm-1-2m-dar-pine-standard_p8401487
https://www.bunnings.com.au/1200-x-810mm-3mm-plywood-pine-premium-bc-grade_p0340268
Tools
Aldi small Table Saw with a slid that I built for this project...
Ozito 850W Router
Bosh orbital sander
Ryobi  Multi Tool
Re: My Little side table....
Afternoon @Super_D
Thats a nice looking table! What type of glue di dyou use? It really looks like its holding up to the job!
Love the lines of it.
Super_D
Becoming a Leader
Thanks for that, it was a fun little project.....
I saw a picture on the net and I also loved the lines like an hour glass, and thought that I can make that, no plan only in my head, I made it up as I went.
I just used PVA wood glue for the 2 main legs and for the straps I just glued in the middle of them, just before they joined each other, and then used the clear varnish as glue as they were very tight and and hard to work out where to put the glue, the clear varnish was good as it soaked into the gapes...
@Super_D
:surprised: Wow, how long has it held its shape? I am impressed with that glue/varnish!
Super_D
Becoming a Leader
Its been only a week, but the 3ply almost stayed in place with out the glue as it has a tight bend on the top and bottom. Vanish does make a good glue, in other applications.
Hi @Super_D
Thank you very much for sharing your side table project. What an artistic and clever assembly. I can just imagine that it becomes an immediate topic of discussion as soon as the person seeing it realizes that you built it. The wavy bent timber is really eye catching, if I had not seen the assembly method, I would probably still be wondering how you got them to bend so uniformly. What was your source of inspiration for this build?
Again, thank you for sharing such a wonderful project.
Super_D
Becoming a Leader
Thanks Eric,
I had to work out to bend them, as I was just going from a photo. One broke but I made a few spare ones just in case...
Ready2go
Building a Reputation
very, very cool project!
how did you keep the top and base parallel while bending the ply?
I glued the main 2 legs in place first, and they were square, then slowly bent the ply...
