How to choose a drill?
nagumuthu
Making a Splash
Hello Members,
I'm looking for a good hand drill machine.  I'm looking for long lasting drill bits as I'm not interested to grind and use it.
1. Can you please propose good hand drill machine @ bunnings.
2. Drill bits used for the purpose of for hanging photo frames, mirrors, small carpentery work, drilling tiles etc.
The drill machine shall cater for drill bits that drills multiple materials (Bricks, plasters, tiles, wood etc.) as on long term I would like to use that for DIY Projects.
Are One time use and throw drill bits available that is cost-effective ?
Thanks for your attention.
Best Wishes
M.Muthu.
Noyade
Re: Which drill?
Hi again mate! @MitchellMc
"was it making the clutch clicking noise,"
Yes, most definitely, with plenty of pressure from above.
Another example. This time soft wood and bigger gauged 75mm screws.
Ozito on the left. I simply gave up at that height seen.
Impacter on the right. It coulda bored that screw right though the wood.
Verdict = defective.
Tyro
Becoming a Leader
Re: Which drill?
Wow thanks Noyade.  I've been at a diy course today and was using a Ryobi cordless.  I've forgotten what the teacher called the timber, but it was wide-ish strips of different grades of pine all glued together.  Some of the strips were really hard to drill!  So your comment about the performance of the Ozito has given me more food for thought (by this stage my brain wants to go on a diet!!🙄😂)
Cheers!
Tyro
Tyro
Becoming a Leader
Re: Which drill?
Mnhhh.  Who cares what day it is ... it's a long weekend!  Enjoy!
Re: Which drill?
Hi MitchellMc
 🙀 Did you use your Ozito for all 3?
Tyro
Becoming a Leader
Re: Which drill?
Hi again Noyade ...not to be a nitpicker but ... it's really ok to strike 'his' for hers! 😉 😂😂
Re: Which drill?
Ahh MitchellMc ... your knowledge bank is amazing!
I need to ask a dopey question ... is the clutch the numbered dial behind the chuck?
(I thought drilling would be easy! 🤯 😂)
Tyro
Becoming a Leader
Re: Which drill?
Oh Noyade!  😱😪😪
Tyro
Becoming a Leader
Re: Which drill?
Oh TedBear!  That is a very highly excellent point! 👏   I didn't even know there was such a product as a cordless screwdriver!  And one so cute too!  What a clever (if somewhat slack!) world we live in!  I think this might be a regular companion when I'm playing at being a woodworker from now on!  Thank you 👍🏻
In accordance with your name tag I send a warm 'Thank you' e-hug! 💞
Cheers! 🤗
Re: Which drill?
Hi @Tyro,
I used the Ozito on all three screws in the video.
The clutch is the number dial behind the chuck. It allows you to easily limit the power of the drill so you can't overdrive a screw too far into timber as per the last screw I drove in. I did that on purpose to illustrate that the drill has plenty of power. So, if you were driving in tiny, delicate screws, you'd set it to one or two or eight for larger screws into hardwood. Typically, once you get the hang of a drill, you'd just leave it on the most powerful setting and ease off the trigger right before the screw head is flush with the surface.
There are no silly questions around here. 😊
Re: Which drill?
Hi again MitchellMc!  Once again you have completed a Herculean task for me by removing the cloudy fog of confusion!  😁👏
I have decided on three new 'toys' ...  As my budget has already been blown by my new plant addiction, I've gone with your recommended Ozito drill driver,  TedBear's Xui cordless screwdriver and Dave-1's  Makita 13mm Hammer drill.  Hopefully that combination ought to cover all of my current and future wood related tasks!  On pondering if I'm doing my usual trick of going overboard, I remember that many, many posters have more than one drill!  The extra $20 for the indulgent screwdriver is my version of a 'reward' ... healthier than chocolate! 🤣🤣
Thank you very much to all members who have provided input on this post!  It's been a great learning curve!
Cheers and 💞 to all
Tyro 🤗
