I received a shipment of yellow tongue flooring and all the sheets have this sticky material on them presumably to stop them from sliding around in the pack during transport. They are going to be used for temporary walls so I need the surface to be perfectly clean so I can paint them. Does anyone know the quickest way to get this stuff off?
Welcome to the Bunnings Workshop community @Leonvdg. It's terrific to have you join us, and many thanks for your question about structural flooring.
Yellow tongue flooring typically comes with a wax coating that helps protect the boards during transport and storage. If you're planning to paint them, you'll need to remove this wax coating, as it prevents paint from adhering properly. Sanding the surface will effectively remove both the wax and the sticky white residue you're seeing. Just be sure to use a medium-grit sandpaper to scuff up the surface enough for the paint to bond.
I took the blade out of a snap off cutter and it scraped the hot glue like stuff off very easily. Thanks for the advice about prepping for painting.
