Simple entertainment unit using laminated panels
wooshka
Making a Splash
Hi, Just thought i would put up a couple of photo's of a simple wall mounted entertainment unit i built using laminated panels from Bunnings.
I used simple biscuits joints to join it all together then a few coats of a clear finish.
Apologies for teh album cover if anyone if offended 🙂
Still some tyding up to do dut i think it will serve its purpose
134827218_212117177122154_3570682846570204273_n.jpg137209345_290535629376184_2351277379274299384_n.jpg
Re: Simple entertainment unit
That's a fantastic project @wooshka, simple and elegant. What did you use for legs, or is it attached to the wall?
Well done and many thanks for sharing.
@MitchellMc I attached it to the wall with a simple piece of quad underneath the bottom shelf , the second shelf has a vertical panel you can only just see in the first photo so i could screw into the wall studs, i didn't want legs underneath, trying to keep it clean lines
redracer01
Hello @wooshka
Beautiful set up. My boys wouldn't know what a vinyl record is if it hit them on the side of the head.
Red
Re: Simple entertainment unit using laminated panels
Great work @wooshka. We have featured the unit on our Project Gallery so it can win plenty of admirers.
