The laundry project
Re: The laundry project
Welcome to the Bunnings Workshop community @rubytuesday1953. It's wonderful to have you join us, and many thanks for your question.
It looks like the talented @Chaks_DIY is single-handedly creating a trend surrounding inBuilt 16mm 1800 x 595mm Natural Wood Melamine Colourboard. Their projects are certainly garnering a lot of attention within the community.
I'm sure @Chaks_DIY can provide some more details, but it looks like the construction is fairly straightforward. I'll include some images below of how it appears to have gone together. You'll need four lengths cut to the same length as the width of the gap. These will be the top and bottom, plus the two rear panels. Cut two lengths 32mm less than the previous boards, as these will be the shelves that fit internally. You'll cut two boards for the side panels 32mm less than the required overall height of which you would like to build the unit. All panels then need to be cut to suit the depth at which you'd like the wall unit to be.
The panels can be screwed together with Zenith 10G x 50mm Zinc Plated Countersunk Head Wood Screws. You'll find the P&N 4 Piece Quickbit Pilot Drill / Countersink Bit Set really helpful at pre-drilling and countersinking your holes simultaneously.
Please let us know if you need further assistance or have questions.
Chaks_DIY
Super Contributor
Hi @rubytuesday1953
Thanks for the appreciation.
@MitchellMc has 'nailed it' 100%. It is fairly simple to put together. The rear panels provide good bracing making it quite sturdy and easy to fix to the studs.
Have fun with it 🙂
Yours Kindly. For more, please follow @hausdiy_weekender
rubytuesday1953
Budding Contributor
Thanks heaps @MitchellMc
They don't appear to be too complicated to make.
Sure come out looking fancy though.
Cudos to @Chaks_DIY
rubytuesday1953
Budding Contributor
@Chaks_DIY
Just love those shelves. They look very unique and add a great touch to the area
rubytuesday1953
Budding Contributor
Just another quick question @MitchellMc
Even though the natural wood  looks good we're going for a black & white theme.
Can this wood be painted and if so, do you have to use special paint?
Rob
mich1972
Super Contributor
OMG !!!! Look at that space. Love it @Chaks_DIY 😍
Hi @rubytuesday1953,
What colour do you want to paint the laminate shelving? You'll be pleased to know that these boards come in various other colours and styles, including white, black, arabica and driftwood. If you did want to paint the laminate, a product such as White Knight 1L Satin Accent Renew Tile And Laminate Paint can be tinted to thousands of colours for you. The timber @Chaks_DIY has used is actually chipboard which is laminate coated with a very convincing timber grain print.
rubytuesday1953
Budding Contributor
That's great Mitchell,
I thought it only came in wood grain. One less thing to paint. Winning!!! 😁
Rob
PS. Well POOP. Just looked at the Bunnings website. No stock of the Black in any of the Gold Coast stores. Just my luck
Chaks_DIY
Super Contributor
Thanks @mich1972 ! Very happy with the final outcome !
I apologise for the out of stock product @rubytuesday1953. That product is actually 595mm wide, and @Chaks_DIY has likely used the 295mm wide version. There is stock available of the inBuilt 16mm 1800 x 295mm Black Texture Melamine Colourboard in the Gold Coast stores.
After the weekend, I'll contact the stores to see if we can organise some inBuilt 16mm 1800 x 595mm Black Texture Melamine Colourboard via our special orders for you if you wanted to build a deeper unit.
