My shower head is leaking even after turning the water off, so I am trying to replace the washer
which tap spanner's size should I use to take off the spindle? Do I have to know the size/type of my current washer before buying a new one?
Evening @nam599
I'm thinking with a flat screwdriver start digging out that silicone until you see the base.
Something like this should help you remove the spindle...
https://www.bunnings.com.au/irwin-plumber-s-tap-spanner-set-6-piece_p0097877
The washers (internal taps) are 1/2 inch (12-13mm) mm...
https://www.bunnings.com.au/fix-a-tap-13mm-1-2-leaklock-tap-valve-2-pack_p4900103
Hello @nam599
It's great that you've received excellent advice from @Noyade. Please follow his recommendations in regards to the removal of the silicone and what tool to use to get your spindle removed.
