Does Bunnings cut wood to size?
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include Melamine and Plywood.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Re: Does Bunnings cut wood to size?
Welcome to the Bunnings Workshop community @timothyleong. It's sensational to have you join us and many thanks for your question about our cutting service.
Unfortunately, we are unable to cut Specrite panels on our saws. This is due to their 33mm thickness and laminated construction.
An alternative option would be to complete the required cuts at home with a circular saw. This handy guide on getting to know your circular saw will be helpful.
If cutting your panel at home is not an option, I'd suggest you speak with one of our helpful team members at your local store's Special Orders counter. The team can order custom-made benchtops in your required size and style.
Please let me know if you have more questions or need further assistance with your project.
Hi there thanks for the detailed reply! I will probably visit the special orders counter then. Thanks!
Keep us updated on your project @timothyleong. If you can't get what you're after through Special Orders, our members will be more than happy to guide you through the cutting process at home. With the correct tools and accurate measurements, you'll have no issues making these cuts yourself.
Please reach out if you need further assistance.
Missskybird
Building a Reputation
Re: cutting easycraft panels
Hi Eric
I was at the Smithfield store today and asked if they would cut one 900 x 1200 VJ100 into three lengths as I did not have a circular saw and I was told they are not allowed to.
I was extremely disappointed and I am not sure whether to just attempt it with a hand saw?
Plus it would be nice to know why they can’t cut it!
Hi @Missskybird,
I'm sorry that we couldn't make those cuts for you in-store. Unlike the larger 2400 x 1200mm board mentioned above, you're looking to have quite a small board cut into three pieces. We have a minimum cut allowance of 300mm, which is in place to ensure the safety of our team members is maintained at all times whilst cutting and that they can safely secure the board whilst they do so. With such a small board, this is not possible on our machines.
If you were fixing architrave or moulding over your cut lines, it would be possible to use a handsaw. I'd encourage you to set up a straight edge to follow along with your saw to ensure a straight cut. Alternatively, if you are looking for a cleaner cut, I recommend you check out our range of circular saws. You might like to read our Best Advice article on What circular saw do you recommend?
Please let me know if you have further questions or need assistance with your project.
migg
Cultivating a Following
Use the selleys Instant Hold when putting it up - $15.90 but well worth it. I used 2 tubes for a 2.4m panel. Be sure you have it lined up cause once it’s on…it ain’t coming off!! 💪
Ilovebunnies
Can an External door be Cut down and do you offer this service in store?
Hi Team,
We need to replace our back door.  We are hoping to use the below product:
Hume 2040 x 820 x 35mm External Door Duracote Flush X1 - Bunnings Australia
Our measurements are 2015 x 820mm - 25mm smaller in height.
Wondering if these doors are okay to be cut down, and if so, can this be done in store?
Bunnings team members rock!
B
Re: Can an External door be Cut down and do you offer this service in store?
Hello @Ilovebunnies
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thank you for sharing your question about cutting down your external door.
I'm so sorry but cutting down doors at the store is not a service that we offer. However, you do have two options when it comes to resizing the door. The first is to go to the special orders desk and ask them how much it will cost to order the door in the size you've indicated. It will cost a little bit more, but the advantage is that it will be professionally built and is covered under the manufacturer's warranty.
The second method is to cut the door yourself with a circular saw. However, the person doing it should have the experience and knowledge to re-assemble the door should they cut too much off the framing of the door.
Thank you Eric for our super fast reply.  I'll chat to special orders.
STARWARS
Custom wood cutting - angled cuts
I am aware that bunnings offers a cutting service however, are they able to do angled cuts? I need a specific wood piece to be 60 degrees. My school doesn't have the capability of doing so as our table saw (or other equivalent equipment) can only do as much as 45 degrees.
