Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include Melamine and Plywood.
What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Re: bunnings cut shop service - 5 cuts per person limit??
Hi @Jewelleryrescue
Couldn't agree more - without exception I've always experienced great customer service every time I've visited bunnings in the last 20 years - except this one time.
Having made a bunch of stuff from wood over the years I made a simple cutting plan that minimized the faffing and needed only 2 set up changes - it was a 2 minute job that would take me about 30 minutes at home and not be anywhere near as accurate.
I'll plan a bit differently next time just in case - just need to do like you suggested and take a mate or two 😊
Thanks @MitchellMc - I appreciate the reply and the private message - thankyou for monitoring the forums and providing support - it's a great idea and 99% of the time bunnings team members are just like you - very helpful, knowledgeable and friendly.
SimoneB
cutting particle board
Do you know if the West Footscray store can cut particle board to size for me?
Hoping to get a 600mm wide board cut in half.
Thanks!
Re: cutting particle board
Hello @SimoneB
Welcome to the Bunnings Workshop community. It's wonderful to have you join us.
It all depends on the size of the cut and the type of particle board you are having cut. A laminated particle board can be cut but be aware that the cut will be rough, and the edge will chip due to the large blade of the shop saw. Small narrow cuts and angled cuts can't be done on the shop saw. I suggest speaking to a team member in the trade yard and telling them the size of your cuts.
However, should it not be possible, there is always the option of cutting it yourself with a standard handsaw. If you wish to invest in a power tool you can go for a circular saw to cut the panel down to size.
I also suggest having a look at these guides:
Please remember to wear personal protection such as gloves, goggles and an appropriate mask when working on your project.
vlo
will bunnings cut 3mm plywood for me.
will bunnings cut 3mm Premium BC Grade plywood for me. I would need 2 sheets of 2440 x 1220mm sheets cut down to 1850 x 810mm and 2 more sheets of 2440 x 1220mm sheets cut down to 1850 x 760 mm
Re: will bunnings cut 3mm plywood for me.
Hi @vlo
I believe it's possible to cut the plywood at the panel saw. However, please be advised that the shop saws are not built to do precision cuts. The cuts can vary anywhere from 5mm to 10mm so please keep this in mind when having your panels cut.
MamaCassi
Teak panels - cutting to size
Hi to everyone ! Just wondering some advice on cutting one of these timber panels to size. I need two 85cm of the Specrite 1800 x 600 x 18mm Golden Teak Acacia Multi Use Panel. Im not sure if bunings can cut to soize for me - am waiting to hear back from the store near me. Screenshot 2024-02-13 093243.png
Re: Teak panels - cutting to size
Hi @MamaCassi,
Please let us know your closest store so I can contact them directly to verify that service is available there.
Many thanks.
JSPiggott
Plywood to size
I want to buy a piece of plywood as the base for a model train set.  I will need to be able to move it and store it vertically,  I have been told it needs to be about 16mm thick not to ben too much.  It needs to be 1200x1600mm.  Can I get a piece cut to that size?   can anyone advise on the plywood to buy.
Thank you
Re: Plywood to size
Hello @JSPiggott
I suggest having a look at the SpecRite 1800 x 1200mm 17mm Formply F17, it is very strong and has a smooth surface perfect for laying tracks. Since it already has a smooth surface finish, there will be no need to sand or fill its surface.
It can be cut down close to the 1600mm size you are after. I say this because the shop saws are not meant for precision cuts, so I would suggest padding your measurements and cutting the correct length at home. I also suggest speaking to the stores saw operator and discussing with them your preferred measurements.
