What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Hi @mattcabs,
I'm sorry to hear of your disappointment regarding this new policy, I understand that it would cause some frustration if you have relied on this service in the past.
I will pass on your feedback.
Please let me know if you have any further questions.
Hi Mitchell
I'm going to reclad my outdoor tool cupboard with Bunnings plywood, which I need to be cut into 2750 x 450mm panels.
I'm aware that Bunnings has recently specified that the minimum length of cut timber is 600mm. Does this refer only to the longest side of a piece of cut timber (that is, length as opposed to width) or to any dimension of the cut timber?
I'm hoping it refers to just the length, otherwise I'll have to look elsewhere to get my panels cut to 450mm wide.
Many thanks for your advice,
Simon
Hi @simonmcg,
Unfortunately, due to a recent policy change, we are only able to cut timber to the nearest 100 millimetres, so it would not be possible to have your plywood cut to this specific size.
I'd be happy to help if you wanted to cut the plywood yourself, however you would need a few tools including a circular saw, spirit level and some clamps.
Thanks for getting back to me, on a Saturday no less. I appreciate that.
If you can forward my disappointment onwards that'd great.
Cheers!
Hi @mattcabs,
We appreciate your feedback, and I can absolutely forward on your concerns to the relevant teams when they are back in the office tomorrow.
In the meantime, please let me know if there is anything else I can assist with.
My local Bunnings offers a cutting service yet when I asked about getting stuff cut to a specific size, I was told it could only be cut for ease of transport and the saw is not exact as it's a rough cut? Should I insist on getting 27 cuts out of a 2200x1200x 6mm mdf board into 80mm strips?
Welcome to the Bunnings Workshop community @Wogolin. It's sensational to have you join us.
Recent policy changes have seen the following implemented:
Unfortunately, we wouldn't be able to cut your 80mm strips due to the above.
Please let us know if you'd like any advice on cutting the strips at home.
Hi there, I am after cutting the timber sleepers 50 X 200 mm (only 2 cuts required)
please guide if there is any option to hire the cutter otherwise which cutter I can buy for getting this done.
Regards
Hi @Mo2,
Are these sleepers that you already have at home or ones that you intend to purchase from one of our stores? We do offer a cutting service in-store for our products. There are some limitations, though: the minimum cut length is 600mm, and cut lengths are rounded up to the nearest 100mm.
If these are sleepers you have at home, then you could purchase a circular saw to complete the cuts. Something like the Ryobi 1500W 184mm Corded Circular Saw would be sufficient. We don't have hire saws suitable for this job.
You'll find this D.I.Y. guide to the circular saw helpful.
If it's just the two cuts, then you should consider using a handsaw. It won't take much effort to cut through the sleepers twice.
Hi @MitchellMc
I was told a few years ago that Bunnings do not cut treated pine. Is this still the case?
