What size cuts can be made and how much does it cost?
Cuts to timber and panels boards are rounded up to 100mm increments. We are unable to do precision cuts. The minimum length of cut timber is 600mm.
Customers are required to purchase any remaining offcuts measuring less than 1800mm.
Multiple timber cuts may incur a charge of $1 per cut.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
We cut both H3 and H4-treated Pine, @Noyade - anything from framing timber right up to sleepers. We can't cut the round logs though.
Hi again @MitchellMc
You may remember an off-line conversation we had a while back about my local store 'unable' ("we don't cut treated pine") to cut a length of H4 in half.
Purely to fit in the car.
So I rang them an hour ago - based on what you say above.
I was told they will cut H3 - but not H4.
Hi @Noyade
I'll reach out via private message for further details so I can touch base with the store. There might be limitations at that store which I am not aware of.
Hi @Noyade They do at my local stores (H3 & H4) as recent as 2-week ago a mate had a couple cut.
Hi @Mo2
@MitchellMc suggestion to buy a shot handsaw is an ideal solution and will come in handy to have in your tool kit.
Hi @simonmcg
Anywhere else you take the timber to be cut will incur a charge per cut. I would consider @JacobZ suggestion to buy a circular saw and use a straight edge to make the cuts yourself. It's a little bit of effort to set the straight edge up, but it's accurate and easy to do. Please refer two photos below. This was a setup to trim a door, but the process he explained is the same.
Many thanks, Nailbag. I really appreciate your constructive suggestion and the accompanying photos.
As I've only ever required a cut like this once in my 60 years, I'm going to see if I can get the plywood cut elsewhere.
Do you by any chance know where, apart from Bunnings, I can get the plywood cut?
I don't mind paying a few dollars for a one-off job like this.
Thanks again,
Simon
Hi @simonmcg
It will take a bit of phoning about as most timber yards only do docking cuts. In other words use a mite saw to cut long timbers to length. Cutting sheets of plywood require a more specialised saw which timber yards don't have. Try Googling "local timber cutting services" However possibly the easiest solution would be to enlist a local handyman as they would be easily able to provide this service for you at home.
Regards, Nailbag
Brilliant. Thanks, Nailbag. Simon
I am planning to make a bookshelf, I live in an apartment and don't have the tools to cut a melamine sheet 2 metres long x 45cm wide, cut into 15cm wide lengths.
