Folding table
Shagen
Junior Contributor
Folding table
Hi, I am new here. This is a great community with lots of ideas.
I have a question which I hope someone with more knowledge and experience can help. I am building a foldable outdoor table. I have the table top done and have wooded legs for them and know how to make them foldable by using a hinge, maybe. However, I am struggling to undertand how I can make the table stand without collapsing once opened. What can I put on the legs or the table to ensure it doesn't shake and fall if the tabled was rocked or shaken, accidentally?
Thanks for your help.
Re: Folding table
Hi @Shagen,
Welcome to the Bunnings Workshop community. Glad to see you've already noticed what a fantastic bunch of clever and creative members we have. We look forward to reading more about your own projects and plans. Feel free to post anytime you need assistance or have something to share with the community.
Let me tag some of our keen woodworkers who might be able to kick off the discussion for you about building your folding table: @Brad, @Rusty-Saw, @gbaker1512, @Johnnynl, @Yorky88, @LePallet, @woodalwaysworks, @r23on, @Poppop
Looking forward to seeing your table project come together.
r23on
Valued Contributor
Re: Folding table
Sketch of your ideas of the folding leg would be great to understand where you are hinging from as there are a lot of ideas on how to stabilise and secure the legs
Brad
Trusted Contributor
Re: Folding table
I think the easy way is to cut the top of the legs at an angle so they splay out a bit.
Re: Folding table
Hi @Shagen,
I'd also like to welcome you to the Bunnings Workshop community.
As @r23on mentioned a sketch of the design would allow us to give some specific suggestions for a solution. @Brad has also given some great advice as many folding tables use an angle cut into the end of the table leg to assist rigidity.
There are many stays which can lock table legs into place like this Prestige 240mm Zinc Plated Steel Card Table Stay or Prestige 131mm Lid Support Stay. Some might be labelled as lid stays but could function just as well when used on folding legs.
Please let us know if you need further advice or had questions.
JDE
Super Contributor
Re: Folding table
Shagen
Try googling Table Leg Brace. Depending on the size of your table Bunnings sells them for card tables.
JDE
Shagen
Junior Contributor
Re: Folding table
@Brad I think I like this idea as it is simple but will it be any more unstable if I had wheels?
Shagen
Junior Contributor
Re: Folding table
Not sure if the drawing makes sense. The legs at each end would fold inwards. But my problem is I’m afraid it may not be stable.
I am building this to place my drop saw and as a general work area.
r23on
Valued Contributor
Re: Folding table
Hi Shagen
as pointed out the stability of the table will be dictated by the size and quality of wheels as a suggestion i would stabilise each leg by bracing each leg this can be done by
some 10mm rod and some 25x25mm angle I will follow up with a drawing later today with a drawing of parts
r23on
Valued Contributor
Re: Folding table
Hi Shagen
Had bit of a think and based on your sketch I have knocked up a drawing (food for thought) For strength I would go down this line to lock the legs in place
The parts I would use
Timber will be based on your need
Hinges https://www.bunnings.com.au/pinnacle-16mm-galvanised-lh-double-butt-security-gate-hinge_p4150137
All sizes based on your needs and I would use two (2) evenly space I forgot if you have your own welding kit you could make your own with some tube, 5mm flat and some 12mm bar
Hope this helps
