How to install portable AC vent in casement window?
ageorge
Hi, I live in a rental house and have a tilting casement window in my bedroom. Unfortunately, it’s the only window available.
The casement window tilts open from the bottom and has a fly screen attached.
My question is: how can I install a portable AC vent in this space?
Re: Portable AC vent
Hi @ageorge,
Unfortunately, there is no simple way to install a portable AC vent to a window like this. You're going to have to build something custom to fit the window.
You'll have to start by removing the flyscreen frame and measuring the width of the channel it sits in.
You can use an aluminium channel that is the same width as the channel the flyscreen sat in to create a frame for a sheet product to sit inside.
You can then use a sheet of plywood or acrylic that is the right thickness to sit in the aluminium channel to block the air from outside.
Most portable air conditioners use a plastic plate that can be expanded vertically but not horizontally, so your new frame should be the width of your flyscreen frame minus the width of this plastic plate.
Cut your plywood or acrylic and aluminium to size and glue the channel around all four sides of it with Liquid Nails. Keep in mind you'll need to cut a notch in your frame to accommodate the window winder.
Allow me to tag @JoeAzza, @TedBear and @DIYGnome to see if they've got any ideas.
Let me know what you think.
JoeAzza
Hi @ageorge  just to add to @JacobZ @suggestion, you make up a new fly screen frame narrower than the original screen, narrow enough to allow the ductwork to fit through to the outside, make up the plywood or acrylic sheet with the duct work hole, attach it to the new fly screen, then fit the screen and duct back onto the window, you can still open and shut the window with the duct pipe in place.
DIYGnome
Becoming a Leader
Re: How to install portable AC vent in casement window?
Hello @ageorge welcome aboard 👍
I would concur with the previously made suggested options, tilt out casement windows are the worst style for this type of modification, that given there's a commercially made product available that at the very least may inspire your own working solution (the elongated outlet is the key to the design) and
given the window is at ground I would  be concerned about just how far it needed to be open.
Olimpia Splendid - Cool Seal
ageorge
Guys ! I just wanted to say a big thanks to each of you who tried to help me out. I am just in my twenties trying to figure all this out.
I managed to achieve a acceptable level of seal which has been cooling my room fairly good.
Amateur fix here with thin pvc foam sheets, duct tape and liquid nails to hold everything together.
Hi @ageorge
That looks excellent, a bit of D.I.Y inspiration and you've got your air conditioning working. Thanks for sharing your solution.
JoeAzza
Hi @ageorge
Problem solved, it’s good to see you had a go at solving the vent issue, well  done.
Noyade
Similar issue with a university dorm window.
I am not 100% sure - but I think the flyscreen is security locked?
I can show you what some students have done - but they will certainly lose some of their bond upon graduation.
Dunno? Not sure how to get around this - and yes, I don't expect a perfect seal.
Noyade
First issue will be getting the unit from car to room.
For that, last night I purchased a 250 kg Top Lift trolley from Bunnings.
https://toplift.com.au/portfolio-item/aft250-folding-hand-trolley/
But just now, testing the weight - before it even begins to lift - the plastic parts start to separate - putting strain on the long rivets and plastic.
Return?
No load...
Some load...
Due to the folding nature, there is always a bit of flex in the mechanism @Noyade. It is rated for 250kg, but keep in mind that a 50kg item requires more force to lift than 50 kg, because its mass is not all at the pivot point due to its width.
I would use it, and if it breaks, return it then.
