Looking for suggestions for my She Shed floor base
Dani64
shed base.JPGIMG_0700.jpgshed.jpgHi all
Im shortly starting a shed from scratch, 3.6 x 2.4, skillion roof.  The book im using is by an english author, called "How to build a shed"  In it they talk about 3 different bases to use.  Timber bearers straight on the ground, Adjustable piles or feet that attach to floor frame and are driven into the earth and a concrete base.  My plan is once I build floor frame, attach short posts into the corners and probably at each side and concrete these into the ground. Would this be ok? im thinking 300 - 350mm deep. would this work?  Or could i do something like this with concrete blocks?
Pics attached of what i hope it will look like when finished :smile:
Re: Looking for suggestions for my "she shed" floor base
Hello @Dani64
Building a shed from scratch is a wonderful project. I suggest going with the concrete blocks DEKO 250 x 150 x 150mm Instant Concrete Foundation Block. However, I would recommend putting some on the outside perimeter of the frame as well. I would also suggest combining it with your idea of concreting posts into the ground. Just keep in mind that the base frame and the posts will be carrying the weight of the shed walls and roof.
I suggest engaging the services of a builder to look at the plan and the proposed base frame to make sure that it is safe and up to code. I also recommend checking the local council rules and regulations regarding the construction of a shed. It's best to cover all the bases before beginning your project.
Let me tag our experienced members @diy_hausdesigns, @Brad, @ProjectPete and @TedBear for their recommendations.
kim-donaldson50
Re: Looking for suggestions for my She Shed floor base
Hi there are you in QLD ? I have this book also and am looking to do one for myself. Do you need a hand on this so I can learn along with you ?
Hello @kim-donaldson50
Welcome to the Bunnings Workshop community. Thank you for joining the discussion.
Let me tag @Dani64 to make them aware of your question. I've seen parts of this book from Sally Coulthard and they use UK conventions. I'm keen to follow along as well to see what floor base they'll be using. But if you decide to build yours ahead, please make sure to post some updates. I'm sure our members would be keen to see how it's built.
We look forward to seeing the start of your timber shed.
Hi @kim-donaldson50 I’m in Tassie! Was planning on starting over Easter however it’s going to rain but I will post updates once I start!
