Large outdoor bench seat, with storage and a side planter box/esky
LePallet
Valued Contributor
B74DF808-3D35-4381-8C5B-ADC78490C799.jpegAll materials are recycled and Have been made into this large outdoor bench seat measuring at 2.3m long, 750mm high, 800mmm wide with the choice of a low table for entertainment
Re: Large outdoor bench seat, with storage and a side planter box/esky
Hi @LePallet,
A fantastic project as always! Was it made from pallets or other recycled timbers?
Many thanks for sharing and we look forward to seeing what you'll build next.
redracer01
Trusted Contributor
Hello @LePallet
Amazing work as usual! Can i request for sizes and number of pallets that you used for this latest creation.
Thanks!
Red
Ange4
Budding Browser
Hi, Is the pallet wood treated? I didn't think it was. So this bench seat will rot if I put it in my garden right?
Welcome to the Bunnings Workshop community @Ange4. It's splendid to have you join us and many thanks for your question.
Let me mention @LePallet so he can give you the specifics on his project.
Most pallets used domestically within Australia are not preserved with chemicals. From my experience, pine pallet boards used out in the weather take many years to decay. It's a great idea to raise them off the ground, so they are not in constant contact with moisture. You can also apply an outdoor oil if you'd like to add to their lifespan.
We look forward to hearing about the projects around your house and garden and would encourage you to let us know if you ever need help or have something to share. I trust you'll find loads of inspiration within the community as our amazing members share their projects all the time.
LePallet
Valued Contributor
Hi there @redracer01 and very much appreciated
the sizing of the timber is 120mm wide,
it you count the number of timber’s used for the height, then look at the overall length. That should give you a rough idea how many lengths of timber you will need for that section and so on.
I hope that helps.
I am lucky enough to have good source for this recycled timber so I’m not actually breaking down pallets but In saying that, this most definitely can still be achieved using pallets @Ange4
LePallet
Valued Contributor
This timber I’m using is HT which stands for heat treated. It hasn’t got as many chemicals compared to treated pine, but what I do know is this has no disadvantage with the timber being outdoors permanently. This timber as well as pallet timber are designed to last all weather all year round and it depends on how well you treat the timber with care such as maintaining it using outdoor oil which will help keep its look and colour.
But like all timber it does weather and brown. But rot is unlikely if looked after and off the ground.
Just think about the last pallet you seen maybe on the ground in a paddock, how many years it’s lasted not treated and it’s still all in tact by nails. Weathered on the outside but once you cut into the timber, it’s a majority of the time clean inside
@Ange4
