How to design a woodworking space?
kalivet
I am president of a new not for profit association (women shed ) in Brisbane, and I’m trying to design a woodworking workshop space (6mx6m) for women in the community to join . I don’t have idea where to start . is here somewhere i can get some designs ideas or tools list ? that can guide me what  i need to set up something good and organised .
Re: woodworking space
Hello @kalivet
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your wood working space.
There are a number of possibilities on how to design this space, but it will depend on what your goals are and what kind of tools you'll be using and what kind of projects you would like to take on. Building workshop tables will definitely be on the list, but even this can be built cleverly to take on several functions. A tool storage area where the tools can be kept safely and securely. A mobile worktable will always come in handy and power points around the area to help with corded tools and charging.
I propose looking at some of these discussions:
I also recommend looking at these guides:
I suggest doing a basic sketch of the number of tables you would like to have in the area. Are you investing in a tool display rack or does everything need to be secure? Look at some pictures online to get some inspiration and incorporate the best bits into your design. Once you have a general idea of what it will look like share the drawing with the community and any other questions that you might have. We will be more than happy to offer ideas and recommendations on how to layout your workshop.
Let me call on our experienced members @Dave-1, @Nailbag, @Remarka6le, @Noyade and @AlanM52 for their recommendations.
Re: How to design a woodworking space?
Just thought I'd tag a few more keen woodworkers for their thoughts on this community project.
@JoeAzza@woodalwaysworks@Alicia_Woodwork
JoeAzza
Hi, @kalivet
All good suggestions from @EricL , you could also try to contact other Men’s or Women’s Sheds to get some help to set you Women’s Sheds in Brisbane. I’m not sure if there are Men’s sheds in Brisbane, I know they have many in Victoria..
you could also contact Op shops for old tools that you can make use of.
Noyade
Hi @kalivet
What sort of projects are you anticipating to make?
My father was a builder - he made a shed with a large barn door.
With a large table-saw and jointer planer positioned such that when the door was opened - he could deal with long lengths.
Just a thought. 😁
Alicia_Woodwork
Having an Impact
Hi there @kalivet,
This sounds like an awesome project! Women’s sheds and women’s carpentry courses are incredibly valuable.
When I started my woodworking journey, I found a drop saw, disc sander and drills the most important. As I progressed a little, I moved to using a table saw, bandsaw, belt sander, router and biscuit joiner.
ideally your space will have multiple small work stations next to the tools with a large main workbench in the centre for any tasks not requiring large stand-alone tools.
Basic small tools such as chisels, sanding blocks, pencils, wood drill bits and wood glue are a must.
I really hope this assists and you’re able to get the shed up and running soon! Please feel free to send me a message if you have any other questions or would like a bit more detail.
Looking forward to seeing how it turns out!
Alicia
Good Evening @kalivet
I think @EricL's suggestion of a sketch to work out how many tables ect you may want for members to work on. I would even go as far as mocking up with cardboard and a 1:1 ratio of the room in question. Mainly to get a feel of the space that you will require around tools/bench or otherwise fixed machines plus workspace for them.
Hand tools will take up a lot less space then having a set drill press or bench sander. A wall with tools mounted on it may be a good option if you can spare access to it. Shadow board cardboard first before deciding on the space needed. It will cost a lot less this way. If you go for a fixed sander you may need dust extraction for the area.
Where are the power points is another question? Will there be any hanging outlets? It all keeps coming back with a sketch to start with. If you could draw up the room and mark out windows/doors plus powerpoints we could suggest what may fit.
